IMAQ SVM Train for not Image data
i'm pretty new to machine learning algorithms on Labview so please be patient if my question seems stupid. I was wondering if there is a workaround to use Machine Vision SVM VIs (ex. IMAQ SVM Train)  for not images data. I know about Machine Learning Toolkit and i'll surely make a try with those but MV VIs are really well organized and allow to save training in a quite elegant way.
Indications, suggestions or, well, even a "No, you can't" is really appreciated!
By the way, any chance to have Learning Machine Algorithm natively supported in LV? 🙂
Thank you,
Frax
(4,327 Views)
There is a separate board for VISION, where you can post queries Specific to Vision.
http://forums.ni.com/t5/Machine-Vision/bd-p/200
I am not sure what do you mean by not Image data?
To Learn Machine Vision Learn Basic Vision Tutorial
http://www.ni.com/example/6712/en/
http://www.ni.com/white-paper/3470/en/
try to explore more about image processing using Vision Assisatant
(4,287 Views)
Accepted by topic author frax84
-As per my knowledge IMAQ VIs are specifically for Images.
-Your best chance is using Machine Learning Toolkit which you already found.
uday
(4,282 Views)
Thank you everyone for the answer,
as udka understood i was trying to investigate the possibility to use the Machin Vision SVM VIs for general purpose machine learning algorithms(input not specifically an image).
I wonder why NI doesn't natively integrate Machine Learning algorithms inside LV but, ok, this is just my mumbling.
Thank you for your help,
Frax
(4,277 Views)
Just to quote someone(AQ) from NI why not, here's the answer: "This is not an area of expertise for National Instruments. Instead, it is an area we encourage third parties to develop, parties with the research background and test facilities to develop such tools."  : https://forums.ni.com/t5/LabVIEW-Idea-Exchange/please-add-machine-learning-feature-into-labview/idc-...
uday
(4,272 Views)
Still....Machine Learning is really well implemented in Machine Vision 🙂 By the way, if they are not willing to implement ML in LV there is nothing i can do to change the fact.
(4,269 Views)
