IMAQ Symmetry - is not executable
I want to get mirror of my image. But I can't use "imaq symmetry" vi because of this error?
Using : Labview SP1 2009error.jpg
Yasemin Barutçu
Electrical And Electronics Engineer
(2,875 Views)
Hi No_RegreTs,
Can you open up the block diagram for the IMAQ Symmetry SubVI and see what is causing the VI to be broken? A screenshot of the block diagram and the error list of the SubVI would be helpful. That subVI is essentially a call library function node, so it's a bit surprising to see that there's an issue with it.
(2,858 Views)
