Control vi profiler for printing a "used memory graph"
Is there any way to control the vi profiler thorough scripting.
I want to take snapshots and show how the much memory each vi takes in a graph. For finding memory leakages.
(2,321 Views)
You can use the VI metrics properties to look at memory of a VI during run-time.  On some older versions of LabVIEW these do not work if you use more than one property per node.
(2,315 Views)
