IMAQ_USB - 1074396024 (Minimum coverage value should be greater than zero)
I'm having problems to use an USB WebCam when I try to run an executable file in a PC that don't have LabView installed. The error code that appears is 1074396024 (Minimum coverage value should be greater than zero).
When I run it in a PC that has Labview installed, everythings works great!
Anyone have some idea to help me? The example program is attached!
Thks
(3,973 Views)
Accepted by topic author Neat
Hi Neat,
To run your executable in a PC without LabVIEW you must install LAbVIEW Run-Time Engine and Vision Run-Time Engine.
http://digital.ni.com/public.nsf/allkb/3EB8C8AFC1593B4A8625712E0002869B
Vision Run-time Engine require license.
Best Regards,
Abel Souza
Applications Engineering
National Instruments Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(3,931 Views)
I have the same problem. I Have a LabView 8.6 with LabVIEW Run-Time Engine and Vision Run-Time Engine, of course i install USB IMAQ drivers. Measurement & Automation is finds the camera and work there (i have the image from camera in that window). When I start VI in LabView the erroc occurs in IMAQ USB Init.
thanks for help.
(3,882 Views)
You can check dlls required to use IMAQ USB Cameras
Abel Souza
(3,876 Views)
Thanks for reply, but still i have this error. In that page, which You send me, they says that "Register ImaqDirectShowExport.dll by selecting the Windows Start Menu and selecting Run. Type in regsvr32 C:\WINDOWS\system32\ImaqDirectShowExport.dll", and my computer occure error with number 0x80070005. I do not know where is the problem. But i will be seek.
greetings.
(3,868 Views)
Hi Mr Abel, I didn't have suceed doing what you said. I installed the software but I don't know how to activate for 30 days (trial) like it was written! Are there other way to do this test?
Thks
(3,859 Views)
You can contact the local NI office to they help with evaluation activation
Abel Souza
(3,843 Views)
