IMAQ add - remove white parts
I'm sure this will have a really easy solution... but I haven't found it:
I am adding two IMAQ images of the same size. I want to make it so one image (which is just a bunch of lines) is on top, and the white background of this image is replaced with the other image.
If I use IMAQ add, subtract or compare it just seems to replaces the entirity of one image with the other...
I have come up with a solution (attached) involving masking, the only problem is that the mask image must be 2-bit and I want coloured lines.
Can anyone help?
(2,742 Views)
Hello MOI maker,
When you say colored lines do you mean that you just want to replace one color with another on your 2 bit mask?  If so you may want to try using a lookup table.  If not, would you be able to provide further elaboration on what kind of coloring you are trying to accomplish?
David A.
(2,708 Views)
I want the parts cut out of my masked image to appear red rather than black.
(2,706 Views)
Hello Moi Maker,
Rather than trying to use a mask to overlay one image over the other, I would instead suggest using the Overlay Bitmap VI.  I would recommend looking at this thread where Andrey Dmitriev has posted an example that does exactly what you are trying to do.
David A.
(2,686 Views)
