01-18-2011
07:15 PM
- last edited on
03-27-2024
10:49 AM
by
Content Cleaner
Hello all,
According to the instruction here:http://zone.ni.com/devzone/cda/tut/p/id/3447
I am supposed to be able to compile my simulink model into .dll and put it into LabView.
However, when I try to create a .dll out of my model by going to Simulation -> Configuration Parameters -> Real-Time workshop. I tried to change the system target file to NIdll.tlc, but I am not able to find that in System target file browser dialog box.
I have LabView8.6, TestStand4.1.1, MatLab2006a.
What is wrong?
Thanks.
Chase.
01-19-2011 12:25 PM
Hey Chase,
This could be version dependent. However, could you try writing the path of the Nldll.tlc in and see if that works?
A. Zaatari
01-19-2011 02:05 PM
I could not find the NIdll.tlc file anywhere on my system. Did I forget to install anything?
01-20-2011
11:10 AM
- last edited on
03-27-2024
10:50 AM
by
Content Cleaner
I am not sure, I dont use Simulink that often. I use CD&Sim for my simulation purposes.
Also you can import your simulink models to it.
Best of luck!
A. Zaatari
01-21-2011
12:37 PM
- last edited on
03-27-2024
10:54 AM
by
Content Cleaner
Hey Bladhart,
After doing a little research, I have found that the .dll file is indeed something from our side. It gets installed with the Simulation Interface Toolkit.
I hope this resolves your issue.
A. Zaatari
10-17-2011 11:50 AM
hello
i have NI labview 2010(service pack 1), matlab 2010a..
How to find it.???
thanks
10-18-2011 04:57 PM
Hi gomugomu,
What was your installation order?
You will need to install the MathWorks, Inc. MATLAB® software before the NI Simulation Interface Toolkit.
Have a great day,
Chris V
10-19-2011 10:20 AM
thanks for the suggestion Chris V.
