How to create a .dll from a simulink model .mdl file
Hello all,
According to the instruction here:http://zone.ni.com/devzone/cda/tut/p/id/3447
I am supposed to be able to compile my simulink model into .dll and put it into LabView.
However, when I try to create a .dll out of my model by going to Simulation -> Configuration Parameters -> Real-Time workshop. I tried to change the system target file to  NIdll.tlc, but I am not able to find that in System target file browser dialog box.
I have LabView8.6, TestStand4.1.1, MatLab2006a.
What is wrong?
Thanks.
Chase.
Message 1 of 8
(5,726 Views)
Hey Chase,
This could be version dependent. However, could you try writing the path of the Nldll.tlc in and see if that works?
A. Zaatari
Applications Engineer
Message 2 of 8
(5,701 Views)
I could not find the NIdll.tlc file anywhere on my system. Did I forget to install anything?
Message 3 of 8
(5,695 Views)
I am not sure, I dont use Simulink that often. I use CD&Sim for my simulation purposes.
Also you can import your simulink models to it.
Best of luck!
A. Zaatari
Message 4 of 8
(5,675 Views)
Hey Bladhart,
After doing a little research, I have found that the .dll file is indeed something from our side. It gets installed with the Simulation Interface Toolkit.
I hope this resolves your issue.
A. Zaatari
Message 5 of 8
(5,653 Views)
hello
i have NI labview 2010(service pack 1), matlab 2010a..
How to find it.???
thanks
Message 6 of 8
(5,396 Views)
Hi gomugomu,
What was your installation order?
You will need to install the MathWorks, Inc. MATLAB® software before the NI Simulation Interface Toolkit.
Have a great day,
Chris V
Message 7 of 8
(5,380 Views)
thanks for the suggestion  Chris V.
Message 8 of 8
(5,373 Views)
