IMAQ: distorsion correction - output resolution
Hi guys!
I wrote a little program in order to correct the distorsion of my camera's images. The output seems to be ok.
Nevertheless I'm in trouble with one thing:
My input image has a resolution of 2591*1944 = 5036904, and the output has a resolution of 1429*3492 = 4990068 which is a little less.
Do someone know more about it? Is there a part of the signal lost? Is it due to the algorithm used?
Regards, Adrien
(3,015 Views)
HI Adrien,
Thanks for posting in the forum. Can you show us the VIs you are using to correct the distorsion of your camera's images ?
(2,959 Views)
Of course, here is the main with 2 images: one for the calibration and one to test.
(2,956 Views)
I have made some researches, and I update my question by "How does IMAQ defines the size of a corrected image ?"
(2,932 Views)
