IMAQ fit Ellipse 2
when triing IMAQ Fit Ellipse 2.vi, from LV2010SP,( create a ellipse array then fit it) I found that the Valid Fit flag will alwys==F if the Reject Outliers==T.
also, change Reject Outliers=T or F will casue the output Ellipse to swap its Major Axis Point1 and Point2.
has anyone noticed this ?  is it a bug ?
cheers
xg
Message 1 of 8
(4,822 Views)
Valid or not - it depends from Minimum Score parameter.
With axis swap - unable to reproduce described behavior (see attachment)
Andrey.
Message 2 of 8
(4,817 Views)
thanks
I could not figure out why you set the minumimscore==0.  if you set it !=0, thing will be different. I added my test code, see the attached.
by changing the Reject Outliers, you will see the behavior I mentioned.
cheers
xg
Message 3 of 8
(4,808 Views)
Yes, you're right, with "ideal ellipse" it looks as described. This might be a bug. I don't see big problems with "swapped" points (it depends how algorithm perform the best fit), but for ideal ellipse we should get valid fit anyway.
Message 4 of 8
(4,806 Views)
thanks, Andrey
I am interested in how you created the contours. can you eloborate  a bit?
cheers
xg
Message 5 of 8
(4,802 Views)
Accepted by xgatc
@xgatc wrote:
thanks, Andrey
cheers
xg
1. Create IMAQ Image, set size, connect it to Image indicator on the front panel, run VI once.
2. Draw ROI manually on image indicator (Closed freehand tool was used)
3. Use ROI property (read access) for obtain contour (connected to Indicator on the front panel) Run VI again - you will get ROI.
4. Convert indicator to constant, set ROI property to write.
Profit!
Message 6 of 8
(4,799 Views)
many thanks
Message 7 of 8
(4,797 Views)
could me anyone please describe the algorithm IMAQ fit Ellipse is using?
Thanks for reply in advance.
Dan
Message 8 of 8
(4,078 Views)
