IMAQ line ROI - Straight Lines
When I select the line tool button on an IMAQ image, I have the option to draw a perfectly straight horizontal or vertical line by holding down the "Shift" key and dragging the mouse.
How can I program a similar function with LabVIEW?
- Sable
Message 1 of 14
(4,498 Views)
Imaq overlay line
Message 2 of 14
(4,465 Views)
If you wanna draw multiple of lines on same image you may use user32.dll file(with call library function node) to hold down the shift key by programmatically.
Try it from as follows snippet,
Keyboard EventKeyboard Event
Message 3 of 14
(4,458 Views)
Thanks SabariSaravanan.M.
Could you please add the vi attachment in LabVIEW 2013?
Message 4 of 14
(4,451 Views)
Message 5 of 14
(4,436 Views)
Thank you SabariSaravanan.M
How does this work exactly?
I may be missing something here.
- Sable
Message 6 of 14
(4,427 Views)
Hello Sable,
                   I forgot to say loading a user32.dll from PC, double click on call library function node and select root directory
                   from C:\Windows\System32\user32.dll here.
                   This is how use to work flow,
                   Step1: key down event to be before starting the process
                   Step2: Use your code here and draw how many lines you want
                   Step3: Key up event to be after ending the process
Message 7 of 14
(4,415 Views)
Hello SabariSaravanan.M,
I am still unable to figure it out. I've attached a simple vi to test the functionality.
Could you please show me what I am doing wrong?
By the way, my objective is to program the "Shift" key down (hold) + Mouse drag that allows the user to draw a perfectly straight horizontal (or) vertical line in IMAQ using the ROI line tool.
- Sable
Message 8 of 14
(4,411 Views)
Try out this!
Message 9 of 14
(4,408 Views)
Hi SabariSaravanan.M,
Thank you but the vi doesn't work as intended. Shift key by default works for an IMAQ image, even without any code.
When I change it to ctrl key instead, I am unable to draw a perfectly straight line.
- Sable
Message 10 of 14
(4,394 Views)
