IMAQ pause?!
hey everyone,
I have a simple program where I grab frames with Dalsa C640. I need my program to have the ability to pause/resuming the Frame Grabbing with a button click.
What would be the simpliest way to do it? Do i have to stop the grab and then resume it? is there a pause option in IMAQ?
thanks!
(3,671 Views)
Accepted by MrNewb
Hi MrNewb,
There is no dedicated IMAQ pause VI, but you could create this behavior by inserting a case structure around your IMAQdx get image VI. The image below is of our simple Low-Level Grab.vi example with a case structure added in that allows the user to choose when images are acquired.
Something like this should give you the behavior you are looking for.
Matt J - NI Tools Network
(3,647 Views)
Here is the code to make this setup work
(3,601 Views)
