IMAQ usb camera->black screen
No, I try to change "name of the image in the "IMAQ Create" vi" also try all "image type in imaq", but still "black screen", also try to add 5-10ms delay; Strange is this that is working in "inbuilt" camera which I have on notebook, but not working on my quickcam logitech, but "grab" is working fine Smiley Sad. Any other suggestion?
Thanks again to all who helped me...
_________________________
Rookie; LV 2011 on WIN 7
Message 11 of 22
(2,799 Views)
If so, why can't you use grab itself.
Silver_Shaper | CLD
Message 12 of 22
(2,785 Views)
Because I need picture(snapshot),not streaming "video"!
Message 13 of 22
(2,781 Views)
Accepted by hlod
Check this.
Silver_Shaper | CLD
Message 14 of 22
(2,769 Views)
It's actually working Smiley Happy ; Now trying to play with delay, it's working on low 0,3s; this is minimum for normal "snap" 🙂
thanks again
Message 15 of 22
(2,764 Views)
Why I cannot create "case" strocture; I need while loop, and try to implement like button, when I like to take "snapshot"; But it's nothing happend, no matter what I try(try several option)..
Message 16 of 22
(2,750 Views)
Try WebCam Monitor.   It should let your preview and grab images from your Imaq camera - http://www.deskshare.com/wcm.aspx
Message 17 of 22
(2,743 Views)
I dont need additional software, for these reason I have Vision module. I just want to implement wit press button.
Message 18 of 22
(2,738 Views)
You should put the button inside the while loop. Otherwise you read it only once.
Best regards 🙂
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
Message 19 of 22
(2,733 Views)
Well, yes,yes; but after that(which I already try); it's "snaping" picture while switch is on; I want this just once a after pressed button... i try with shift registor on while loop and "and" but it's not working 😞
Message 20 of 22
(2,729 Views)
