IMAQdr - Frame, trigger and grab control.
Ok, so I have DALSA camera connected to my PC and the connection works fine. Im trying to figure out how to control the frame, trigger and grab attribiutes. My camera is comptaible with LabView. I checked some VIs in the Find Example section but these are too complicated for me. Any help would be appreciate.
Kind Regards,
Peter
(3,288 Views)
Do you have Vision and motion package ?
(3,286 Views)
yes i do, I got everything installed. I just need to figure out what to do to control frames, trigger and grab.
(3,279 Views)
Here is something to get you started. Let me know if it helps. Robot Very Happy
(3,268 Views)
do you have any idea how to control frame rate? do i use IMAQdx property node? i tried that with no results.
(3,257 Views)
(3,256 Views)
I use property node to set/get attributes from the camera. can you attach your code so i would see ?
(3,244 Views)
