Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
ISA Bus Interface
ISA Bus Interface
the_intern
Member
08-03-2007
09:58 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
TO WHOM IT MAY CONCERN:
I am using 40+ clocked digital lines from two NI PCI cards that will control my ISA Bus Interface.
How do I design this ISA Bus Interface in the LabVIEW ? I have 16 Address lines and 16 Data lines, and several other lines. Any suggestions ?
0
Kudos
Message
1
of 4
(3,647 Views)
Reply
Re: ISA Bus Interface
Erik_J
NI Employee (retired)
08-06-2007
06:57 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I'm curious, what is your overall application/goal of this project? And what specific NI hardware are you using?
Erik
0
Kudos
Message
2
of 4
(3,621 Views)
Reply
the_intern
Member
Author
08-07-2007
03:08 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I am using NI PCI-6541 and NI PCI-6289. I have ISA Bus interface on PCB card, and need to be able to test it (ISA Bus) using these two cards.
0
Kudos
Message
3
of 4
(3,610 Views)
Reply
David L.
08-07-2007
02:21 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi Intern,
I believe this issue is the same as your other post,
here
. Let's continue in the other forum.
Thanks!
David L.
Systems Engineering
Kudos
Message
4
of 4
(3,597 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
