ISMATEC peristaltic pump REGLO Digital -- LabVIEW control
I have acquired a ISMATEC peristaltic pump REGLO Digital. It works well and now I’m trying to control it via LabVIEW. I have installed its driver (available on your website: http://www.ismatec.com/int_e/downloads/software/download.htm)
However, I can’t control (or don’t find) the pump flow rate. The code runs well (no errors). I can turn it on and off, and set it to operate clockwise or counterclockwise, but I can’t set the flow rate that I desire.
Is it possible to control the flow rate via LabVIEW of the above mentioned pump? If so, how?
Thank you for your help
(2,859 Views)
Hi Tfrl,
I guess you read the programming manual for your pump. And/or have asked the manufacturer for support!?
What is the result of those tasks?
(2,814 Views)
Thanks for your quick reply.
I've tried to contact the manufacturer but no reply so far.
The manual doesn't explain anything. It seems it's possible to control the flow rates but I'm not sure, that's why I'm asking it here.
My intention is to control the pump (turn on and off, set the flow rate and the direction) via LabVIEW.
(2,805 Views)
Hi Tfrl,
All this is possible - when/as long as that pump allows to set all those parameters! Does it provide commands for flow rate adjustment?
Apparently you can switch on/off the pump: are there also commands to set/get flow rate?
That's why I asked for the programming manual…
(2,800 Views)
I recognize that it's been a number of years and I am not the original poster, but I am trying to do the same thing. I looked through the commands provided in the manual and it is possible to set the flow rate
(557 Views)
