IVI Driver code in labview
  I need to develop a code which will control  any DMM instrument using IVI driver. does any one know how to write the wrapper for this
Regards
Parthipan
Message 1 of 15
(5,479 Views)
Do you want to write the IVI Driver itself in LV or just the wrapper alone? Smiley Indifferent
Your wordings are not clear.
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 15
(5,468 Views)
 only wrapper but the same code should work for different model of iDMM(ex agilent and NI)
that is if my wrapper is open input to my wrapper is model no. It should open the particular model DMM.
I mean to say OPEN wrapper is generic to all DMM instrument.based on the input (Model no or something) provided to
the open wrapper it should call the particular model DLL
Regards
Parthipan
Message 3 of 15
(5,463 Views)
Maybe you can use an Enum consisting of all the available instrument model numbers.
Then, accordingly you can have different CS inside each of these will be the respective DLL.
This way, you can go on creating your wrapper for the generic iDMM Open function.
Message 4 of 15
(5,453 Views)
hi,
 I dont get it. what is CS .do u have any sample for it
Message 5 of 15
(5,450 Views)
CS means Case Structure, ES means Event Structure, SR means Shift Register & so on...
You read this for more details.
Message 6 of 15
(5,447 Views)
I don't understand why you think you have to write anything. If you are familiar with IVI, you should know that all that you have to do is use the class driver that is on your palette. When you want to change to a different instrument, you change it in MAX.
Message 7 of 15
(5,438 Views)
hi,
  I read it .I have coded using IVI driver for Agilent34401.i f need to change it to other vendor.what changes i need to make.
Regards
Parthipan
Message 8 of 15
(5,418 Views)
  I tried to configure Agilent34401 using labview .when i installed  i gor IVI DMM Palate.In that  pallate I have used IVIDMM Initialize to initialize agilent In that vi it has asked Logical name as input.I dont know what to give.I dont want to initialise using Agilent initialize.vi.i need to know how to map the logical  name with the agilent34401
Regards
parthipan
Message 9 of 15
(5,409 Views)
The assignment of logical names, etc. is all done in MAX. open MAX and right click on "IVI Drivers". The window on the right side has help such as 'Logically name a driver session'. Follow the directions. You can also see this tutorial.
Message 10 of 15
(5,400 Views)
