IVI Driver code in labview
hi,
   I have configured using max.I uses IVI dmm Initialise function.it thrown error as  FILE NOT FOUND
Regards
Parthipan
Message 11 of 15
(1,700 Views)
Not sure. You may not have everything installed such as the IVI Compliance Package or you missed something in MAX. In MAX, expand the software section and show the Logical Names and Driver Sessions. Select the driver session>Software you are using and take a screen shot. Attach the screen shot.
Message 12 of 15
(1,693 Views)
  I have attached the screen shots
Regards
Parthipan
Message 13 of 15
(1,674 Views)
What version of ICP do you have installed? As Dennis mentioned if you expand the Software section (above IVI drivers) you can view the version.  If it is an old version it might be missing the COM Adapters, it seems you have an IVI-COM driver and not an IVI-C driver as indicated in the IVI3.bmp screen shot.
Message 14 of 15
(1,661 Views)
Hi what i need to do for it what are the thing i need to downdoad and install it to work
Message 15 of 15
(1,630 Views)
