Iam a novice using solaris 2.8 with labview 6.02. I am receiving the error me
ssage "(HEX 0xBFFF003C) insufficient system resources to perform necessary memory allocation" message when attemping execution of a VI containing correctly wired visa Write and Read icons. Visa has identified the resource and through Ibic I can communicateI am getting the error code -1073807300
(3,107 Views)
ssage "(HEX 0xBFFF003C) insufficient system resources to perform necessary memory allocation" message when attemping execution of a VI containing correctly wired visa Write and Read icons. Visa has identified the resource and through Ibic I can communicateThe information you give is useful but not complete enough to pinpoint the problem.
1) Which VISA call returns this error? Is it VISA Open or is it the I/O calls?
2) What resource name are you using?
3) What type of GPIB controller is this? SB, PCI, ENET, or something else?
Dan Mondrik
(3,107 Views)
ssage "(HEX 0xBFFF003C) insufficient system resources to perform necessary memory allocation" message when attemping execution of a VI containing correctly wired visa Write and Read icons. Visa has identified the resource and through Ibic I can communicateThank for the response. I am using a GPIB-ENET/100. The
resource name used is "GIGA_8542" an alias for GPIB4::13::INSTR, the Gigatronics power meter at address 13 which is connected to the gpib-enet/100. I am making a *IDN? call to the device using a "VISA WRITE". There is a "VISA READ" configured for the test equipment response. The error code -1073807300 occurs at the output of the "VISA WRITE". Again Visa has identified the resource and through Ibic I can communicate. Thanks.
(3,107 Views)
ssage "(HEX 0xBFFF003C) insufficient system resources to perform necessary memory allocation" message when attemping execution of a VI containing correctly wired visa Write and Read icons. Visa has identified the resource and through Ibic I can communicateI noticed that this discussion faded in September. Have you found a solution, I am having the same problem.
(3,107 Views)
ssage "(HEX 0xBFFF003C) insufficient system resources to perform necessary memory allocation" message when attemping execution of a VI containing correctly wired visa Write and Read icons. Visa has identified the resource and through Ibic I can communicate- Are you explicitly opening the resource before you try to write to it? LabVIEW lets you call implicitly open a session by calling a VISA write on an un-opened resource. Try opening the resource before writing to it and see if the VISA Open or the VISA Write returns the error.
- Check to make sure that your ENET is set to system controller.
- Do you have Tek VISA or HP VISA installed?
- What version of VISA do you have?
(3,107 Views)
