monitor on and off
I'm trying to turn my monitor on and off in a labview program. I've almost got the solution, but with my code Labview generates an error when it executes the dll. Does anyone know why??
(3,480 Views)
could you explain what you are trying to do?
I have seen that you are sending a Windows message to a Window where the front panel resides in.
What is the message 0x112 expressed in WM_ mnemonics?
Are you aware that the SendMessage will be a call going into another thread? The front panel can reside in another thread as the block diagram will be executed.
There is no documentation available what LV will do with Windows messages send to it.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,480 Views)
I'm trying to turn off a tft screen when nothing happens in my program and I want to turn it on when the user of the program should know something. I'm not very experienced with calling dll functions, so I copied some code from the internet and I've tried to combine it. The message 0x112 stands for WM_SYSCOMMAND. The message 0xF170 stands for SC_MONITORPOWER. I'm not sure I should send the message to the window where the front panel resides in, but I don't know where to send it to otherwise. If someone knows this, how do I get the window handler to it??
Thanx,
Boelens
(3,480 Views)
> it??
When you send a window a message, it may process it and do what you
want, or it may get ignored. If you are sending this messge to a LV
window, LV will not process it a
nd will either pass it to the system, or
refuse it. You might want to try sending it to the explorer or to the
NULL window.
Greg McKaskle
(3,480 Views)
Check out the following post:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=5065000000080000004C610000&ECategory=LabVIEW.LabVIEW+General
There is a link to George Zou's website, who created a VI to shutoff a monitor.
Hope this helps-
Julie
(3,480 Views)
