Icon Editor in LabVIEW 2025 (64b) crashes LabVIEW
I have for the first time switched over to 64 bit LabVIEW programming with LabVIEW 2025. Not much different from working under 32 bit, except problems with the Icon Editor. Every other time I open it, LabVIEW crashes completely and quick ,without any warnings or error messages. Just drops out. The issue is reproducible, and happens on several computers/installations. Anybody else experienced this ?
Martin
(1,101 Views)
yes, others experiensed issues using clear and list glyphs from templates.
Actor Framework
(1,067 Views)
Martin
That was an major issue before the 2025 Patch 1. There is now a Patch 2 available. Try installing those patches and see if that fixes your issue. You should be able to update through NIPM.
(1,034 Views)
I have LV 2025 Q1 64b 25.1f0
Where do I find patch 2, and what is NIPM ?
Martin
(932 Views)
Martin
I think NIPM is NI Package Manager (https://www.ni.com/en/support/downloads/ni-package-manager.html?srsltid=AfmBOoo3omTqLWfZsifZjlkKkHqa... )
(919 Views)
