Ideas for DUT Testing
I am new for Labview. Now I want to read (T1 &T2) Ohms and Voltage from DUT & need to write values in excel .
I want to  use FLUKE DMM with Labview.
My questions are:
1.How to read voltage & ohms from DUT? Need any additional hardware like multiplexer or have any best solution?
2.How to write values in excel?
3.How to make auto trigger or Autorun if Volte from DUT detected?
(1,811 Views)
Altough it's rather not a complex task, you will need a basic proficiency in LabVIEW to prepare it properly.
To read measurement you probably need to use NI-VISA library. Your FLUKE is surely compatible with SCPI protocol, alternatively you may look for a specific libraries for your model.
To write into Excel you may want to use Report Generation toolkit, but usually a simpler and convenient way is writing into CSV file, which can be read in Excel as well. Actually it can be done by a single VI: Write Delimited Spreadsheet.
All the rest is up to your imagination and LabVIEW proficiency 🙂
Mateusz Owczarek
Certified LabVIEW Architect
Certified TestStand Architect
(1,798 Views)
