Ideas regarding RT and Host communication interface architecture
Hello All,
I need to standardize comunication interface between RT and host vis, which is the best way to implement with scalability for the future  needs?
(2,668 Views)
Hi ksn,
Here is a knowledgebase that lists your options for communicating between the host and RT system.
Warm regards,
Karunya R
(2,644 Views)
Hi Karunya_R,
Thanks for ur reply.
Already communication is implemented using network shared variables and some variables  with RT FIFO enabled  in the random manner i.e then and ther inside RT & host vis .My question is I want to optimize/standardize  the communication ie  for example seperate subvi or communication engine.
Please give me some ideas reg this.
(2,622 Views)
Simple message Protocol will be the easiest way to communicate through standardized VIs. There is an entire Developer Zone article and an example program on this. There is also the option using command based functions.
It would be helpful if you could tell me what are you trying to achieving through optimization or standarization?
Warm regards,
Karunya R
(2,598 Views)
