Identifying 2nd and 3rd Loop in a Graph
Hello everyone,
I have a question for those who are talented in signal analysis using LabVIEW. I have a graph (attached below) in which I have to identify the 2nd and the 3rd peak values as well as the width of the first peak that's marked as 'W' in the image. Is there any one who can help me with that?
Add 273 on whatever Celcius said.
-Kelvin
Message 1 of 33
(7,119 Views)
Check "Waveform peak detection"
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 33
(7,105 Views)
With the waveform peak detection I am able to get the first peak's value but not the second or the third ones.
-Kelvin
Message 3 of 33
(7,101 Views)
You should get an array of peaks as output and should thus be able to get all analyzed peaks. Does this not work for you?
/Y
Qestit Systems
Message 4 of 33
(7,082 Views)
You have to properly set the width- Parameter of the peaks. I was with these parameters successful:
Btw, there seem to be a bug in the copy-paste-function of the waveform graphs. On the FP the cursors are set correctly to the peak- values. I will post this in a different thread.
Greets, Dave
Message 5 of 33
(7,049 Views)
That isso nice Dave, thanks. I actually need to identify the peaks programatically. So I guess I have to develop the program you share with me.
-Kelvin
Message 6 of 33
(7,020 Views)
Btw, below I share with you the actual vi I am working on. I need to identify the peak points for the reflection graph that is highlighted red in color. I hope now you have a better idea about what I am trying to do.
-Kelvin
Message 7 of 33
(7,017 Views)
unfortunately I don't have LV2016 installed yet. Could you save ist as 2015- version?
Greets, Dave
Message 8 of 33
(7,006 Views)
Hello Dave, Sure. I have attached 2015 version of the same program.
-Kelvin
Message 9 of 33
(7,000 Views)
This doesn't really help me, sorry. There is no data I can work with.
Please run the VI once, then when there is data shown in the waveform graph, right-click on it and select "Data Operation / Make Current Value Default". Then save the VI and post it again (LV2015 Smiley Very Happy)
With that you send me the data you try to analyze. I would change the waveform graph to a control and don't need the source you get your data from.
Greets, Dave
Message 10 of 33
(6,994 Views)
