If MATLAB script nodes are only available in Windows version. How would you intergrate MATLAB code with LABVIEW code in a MAC?
One alternative is to convert the MATLAB m-file into a C/C++ code. Then you can use the LabVIEW functions for calling external code.
There is a tool for MATLAB, the MATLAB compiler, that do that for you. It can be expensive, though:
http://www.mathworks.com/products/compiler/
Regards
www.vartortech.com
(2,951 Views)
