If Switch is on, toggle action/led once.
I'm trying to make it so that if I turn a switch to the on(true) position, then an led toggles on just once before turning back off. I can't figure out how to have it toggle rather than just stay on. also, I cannot change the action of the switch to only turn on while the switch is being held closed as I need that switch to work with other parts of my code. Any advice?
Message 1 of 9
(4,589 Views)
Accepted by topic author riahim
Hi riahim,
search for the Pt-By-Pt-BooleanCrossing function…
Message 2 of 9
(4,579 Views)
Shift register or feedback node.  Compare new state of switch versus previous state.
Or use the Boolean Crossing Pt by Pt subVI.
Message 3 of 9
(4,577 Views)
Thanks, I'll take a look into the boolean crossing.
edit: Am I missing something? Currently, I can see the input toggle inside the boolean crossing function, but nothing is triggered...
Message 4 of 9
(4,560 Views)
Hi riahim,
why do you constantly reset the boolean crossing function?
(What is this boolean TRUE constant good for?)
Message 5 of 9
(4,543 Views)
I don't want to constantly reset the function. I figured I needed a way to initialize the boolean crossing, but now you bring up a good point. Do I only need to initialize it once or can I leave this disconnected...
Message 6 of 9
(4,540 Views)
Hi riahim,
you have several options:
- leave it unwired
- init by comparing loop iterator "i" for "=0"
You should also put a small delay (aka Wait function) into the loop. No need to iterate as fast as your CPU allows…
Message 7 of 9
(4,515 Views)
Thank you! It is now working
Message 8 of 9
(4,512 Views)
If you don't need all that extra functionality of the ptbypt subVI, all you need is a simple feedback node as follows.
(That's what I typically do :D)
Message 9 of 9
(4,498 Views)
