If true condition for a button in labview
No, I want the resistance be control. So We enter the initial value , & the amount to increase each time the loop runs and loop runs for T period ( I haven't added this part). Here is my code so far
Message 11 of 26
(2,034 Views)
Move the Resistance control outside the loop and wire it to the initiation for the shift register. Other than that I think you have the right idea. Clean up your wires - you can't see exactly where each wire leads and this can lead to subtle bugs. For example, looking at your code, in your false case check that what you are wiring to the output tunnel is correct. It looks like right now it is actually wired to Resistance To Add, which will make it reset to that number whenever the Up button is not on. I don't think that's what you want, though I'm not sure.
Also, why is the Up button a typedef? Did you do that on purpose because you are planning to customize it later? If not, you don't need it to be one.
Message 12 of 26
(2,024 Views)
For some reason my case structure never gets executed!
Message 13 of 26
(2,021 Views)
Why do you think it's never being executed?
Message 14 of 26
(2,019 Views)
When I run the program , resistance doesnt increase when I press the button.
Message 15 of 26
(2,015 Views)
That's because you are not writing to the Resistance from within the loop. I see you added a new indicator called New Resistance. That's perfect, just move it to inside the loop if you want it to update before the loop finishes.
Message 16 of 26
(2,012 Views)
Also, just to note, it increases very quickly since there is no wait in the loop. I would recommend adding a wait to the loop and/or looking at what altenbach said earlier about latching booleans.
Message 17 of 26
(2,010 Views)
This is with new value inside the loop..still nothing..
Message 18 of 26
(2,008 Views)
Sorry, I should have been more clear. You also need to wire it to where you want it to update from. So, use the wiring tool to click on the wire coming from the output tunnel of your case structure and into the output tunnel of the shift register. Wire this branched wire into your indicator.
Message 19 of 26
(2,004 Views)
Ahhh..I finally see something 🙂 One problem though..I want each time I push the button this iteration happens . Currently once the button is true it keeps adding until I turn off the button
Message 20 of 26
(1,998 Views)
