Illegal state [L46208632]
My VI will randomly quit on me with the following error:
Illegal state [L46208632]: 3: RtSchedulerII.cpp,line 1725
sometimes it runs good for a while, but it will always crash with this error eventually. Then I have to force quit labview because it will indefinitely try to reset the vi.
Thanks in advance.
(2,845 Views)
Hi rBackman,
what do you make in your vi. Did you try to copy the entire content into a new vi? Maybe it helps.
Mike
(2,833 Views)
Do you have the rest of the error log?
Justin Parker
Product Support Engineer
(2,786 Views)
Where is the error log located?
(2,761 Views)
Hi Backman,
It depends.  Are you getting this error on a host machine or on an RT target?  If it is the host machine it should pop up when you choose it investigate the error.  If it is on the target machine, go to MAX and right click on the target and select View Error Log.
Are you able to consistently reproduce this error?  Does this always occur after running for a certain amount of time?
Have a great day
Justin Parker
(2,707 Views)
