07-23-2006 10:44 PM
07-24-2006 01:21 AM
04-01-2008 12:22 PM
04-03-2008
10:40 AM
- last edited on
09-21-2026
08:01 PM
by
Content Cleaner
Hi Coato,
As you know, you cannot acquire analog signals with multiple DAQ Assistants at the same time. I was wondering if you could provide some more information about the acquisition you are trying to make and the purpose of the case structure. A few important things to note: do you want to acquire continuously on all channels at the same time and how are the cases changing (i.e. user interface, time elapsed). If you do need to sample multiple channels with different sampling rates continuously, you may want to check out this article which discusses a way to accomplish this using the DAQmx API.
Kent
12-01-2008 01:34 PM
Hi
I have two seprate vi which are supposed to work at the same time, actually one of them measures datas (LCM.VI) and the other controls the equipments with defined schedule (schedule.vi).
each Vi works correct separately, but when I run both at the same time, Error 50103 appears. I don't know what should I do.
I would be grateful if you take a look at my files (LCM & Schedule) and give me your valuable tips.
Best Regards
Amin
