Image Processing - Unable to create an image from array
Hi everyone,
I am trying to create an array from a colored image. Then, from this array, I am trying to create another image. It should give the same image but in gray. However, I am not able to do that. I need this program to understand I am in the right way. This is just beginnig. After I do this, Some calculations will made on array obtained from image.
The vi is at the attachment. Thank you
(2,955 Views)
Accepted by musti168
Hi musti168,
You're going through your entire image pixel-by-pixel and getting each of their values - why don't you just use the IMAQ ImageToArray function?
On this forum post I found an example of IMAQ ArrayToImage: http://forums.ni.com/t5/LabVIEW/IMAQ-arraytoimage-example/td-p/68418
You can use some of the IMAQ Image Processing palette to change the image to gray scale - possibly a threshold.
Julian R.
Applications Engineer
(2,916 Views)
