Implementing Kalman Filter
Good afternoon,
I'm trying to implement a kalman filter to run on my cRIO. I've got a working simulation with a non-linear model in Simulink, using their kalman filter blocks (in continuous time).
State Space Model
I've built a state space model from the non-linear model, and have ended up with (note this is in the attached VI, within the KF block itself):
A =
     0     1     0     0
     0     0     0     0
     0     0     0     1
     0     0     0     0
B =
         0         0
   -7.0071    0
         0         0
         0   -7.0071
C =
     1     0     0     0
     0     0     1     0
D =
     0     0
     0     0
Q =
     1     0
     0     1
R =
     1     0
     0     1
N =
    0
Comparison
I've written some constants to the simulink KF, to get an idea of its response (not for use, but to find out if I'm getting it working in LV):
Note: my R co-variance is outside the KF as it is not time-invariant.
This gives the following 'characteristic':
Attached is a simple vi, where I'm attempting to do the same as above (again, in continuous time):
The problem I'm getting is when I run, I get the following error:
Possible reason(s):
Control Design and Simulation: (Hex 0xFFFF5D24) The dimensions of the covariance matrix are improper.
Complete call chain:
NI_CD_Dynamic Analysis.lvlib:cd_Check Covariance.vi
cd_Verify Stochastic State-Space and Noise Models with xhat(0) and P(0).vi
cd_Check Models Change for Continuous Recurisve Kalman Filter.vi
CD Continuous Recursive Kalman Filter.vi:Instance:4:520001
CKF_characteristic.vi
I'm pretty sure I'm inputting my matrices above have been implemented correctly, but its likely I'm doing something wrong here, does anyone have any ideas?
Peter
(4,636 Views)
Accepted by peterdavidgrant
Hi Peter,
Have you tried editing the size of your Initial Estimation Error Convariance Matrix t0 4x4?
Control and Design User Manual
Rebecca
(4,552 Views)
Hi Rebecca,
Thank you for the reply!
Ahh thanks, I thought that configuration parameters like that would have sized automatically, so left it as was, if it was required, so it is now working:
I'm still getting different results to my Simulink model though, I can't work out what else might be different when functionally they should be the same. I'll have a go on the real thing, and see what happens.
I've started digging through the control and design user manual, thanks!
Peter
(4,544 Views)
