03-18-2011
01:34 AM
- last edited on
04-13-2026
01:30 PM
by
Content Cleaner
Hello everyone,
I'm trying to implement SPI protocol using PXI-7833R, so that it should behave as a SPI master and should be able to communicate with a SPI device (treated as slave).
Now I already found an example, but the problem is, this example uses cRIO-9103 as FPGA target and in my case I'm going to use PXI-7833R as FPGA target, and when I'm changing the target (from cRIO-9103 to PXI-7833R), I dont know how to map I/O's listed under 'Chassis I/O' (under cRIO) to the new target (which is PXI-7833R).
03-18-2011 06:04 AM
Hi All,
Somehow I was able to change the target (from cRIO to PXI-7833R).... but now I'm getting an error while trying to compile the code.
The error description is:
"Multiple objects are requesting access to a resource through a resource interface from both inside and outside the single-cycle Timed Loop, which is not supported.
