Regarding Report
Hello sir
        To test a horn board i have created vi, Each test is carried out using a case structure..i have created  a vi which creates an excel file and saves the  the test values when each case is executed..i like to add colour to the Report, how to create report with coloured fonts..
  This is my next question for the same test i have created report using Report generation tool kit in which i dont how to insert the test values which is obtained during each case..
 In the first method i  got the required report except the font colour,size whereas in the second method i dont know to get the exixting case value, is there any icon for this..im using LabVIEW 10.0
(2,616 Views)
1) There is an example for reports in excel.  Go to examples\Report\Excel report.llb
2) in the same example folder you can find examples on how to create reports and how to insert tables into a report
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(2,605 Views)
