Web Server with Mozilla Firefox on cRIO
I am using a web service on my cRIO-9012.  I am developing my code on a windows box, but eventually the cRIO will be connected to a linux box.  Only Firefox is available on the linux box.  While testing on my windows box, IE seems to load the web service fine, but firefox has a small little dot instead of the front panel.  I've read somewhere that Labview detects what browsers are installed and provides a plug-in for those browsers, but I have just upgraded to Labview 2010 after having firefox on my computer.  I notice that on IE asks to use activex content, and knowing firefox doesn't have activex.  Is that the reason why?  Will I have this issue on my linux box connecting to the cRIO?
(2,705 Views)
As of now, you will not be able to use Web Services on your system with the Linux O/S. The Web Services FAQ below provides more information about this and Web Services.
LabVIEW WebServices FAQ
http://zone.ni.com/devzone/cda/tut/p/id/7747#toc2
Best,
(2,673 Views)
