Implementing "pause" function in GUI
Hello fellow engineers!
I would like some help from all of you. I am trying to implement a GUI in Labview. I want to know how I can realise the "pause" and "continue" functionalities. I welcome suggeestions from all of you.
With warm regards,
Aparna.
(3,155 Views)
Hi Aparna,
I was not quite clear of what you were after but i have generated a small VI for a solution I think you are after. Hope it helps.
Kabul
(3,142 Views)
Aparma,
I use state machines which have a Paused or Idle state. The Pause button is has Boolean text = "Pause" in the False state and "Resume" (or Continue) in the True state. Other User Interface methods include Radio Buttons: Idle, Start/Run, Pause, Resume, Stop or an enum with similar items. The state machine architecture gives you great flexibility in how you handle the user inputs.
Lynn
(3,133 Views)
