LabVIEW DSC 8 Alarm State shared variable
it was possible in LabVIEW 7.xx to read the alarm state with "Read Tag Alarm".
I didn´t find such in LabVIEW 8.20.
I testet "Read Alarms" and the "property knot".
Thank you
Torsten
(11,620 Views)
Hi Torsten,
to read the alarms in Labview DSC 8.20 you can use the "Read Alarms.vi" in combination with the "Format Alarm data.vi".
You are using shared varibales with DSC 8.20. There you can set the proprties (attached Screenshot.zip)
In Labview you can get these alarms with the two VIs (see above).
I also attached a little example project. There you can open the "DSC Read Alarms Demo.vi" inside of the program to see how it works.
Hope this helps
Best regards
Dippi
(11,608 Views)
Hi Dippi,
thank you for your fast replie.
I need the Funktion of the Demo in an other VI.
But my first question was only to read the tag/shared variable state.
I attached a sample as picture.
Best regards
Torsten Lochner
Message Edited by Torsten Lochner on 07-13-2007 08:37 AM
(11,589 Views)
Hi Torsten,
in Labview DSC 7.1 you were working with Tags. In Labview 8.2 DSC you are working with shared variables.
So this VI won't exist in that way anymore.
If you want to read out the state, you have do do it e.g. like this (see attached jpg filfe).
I wish you a nice weekend.
Best regards
Dippi
(11,579 Views)
