Import CBX Spinner Object from lookput
I was a Lookout developer, it was beautiful software, now i want to import some object in Labview like spinner object "spinner.cbx" It starts spinning when my digital input is High.
Please explain how i can import objects  in Labview
(2,813 Views)
Hi M_Atif,
I am not aware of any way to import a CBX object into LabVIEW.  Lookout and LabVIEW have similar capabilities but the processes to implement them in each program are different.  Code written in Lookout needs to be rewritten in LabVIEW.
If you have an ActiveX Object, that can easily be called from LabVIEW as explained here
Jennifer R.
(2,789 Views)
