Importing data from Excel.
So I am importing data from an excel file. I get all the data correctly except one cell. There is a cell in excel where a date is stored. The value is 26.01.2023. But in LabVIEW it is coming as 44952. Can anyone explain why this is and how can I correct it? Thank you.
(2,044 Views)
Accepted by govindsankar
https://forums.ni.com/t5/Example-Code/LabVIEW-Time-to-Excel-Time-Format/ta-p/3503346
It's explaining how to convert from LabVIEW to Excel, by reversing the VI you can do Excel to LabVIEW.
(2,030 Views)
Check this out
Simple Excel Date/Time to Labview - NI Community
(2,017 Views)
