Importing from a Spreadsheet and Exporting to a Spreadsheet Crio Chassis
Hi I have a Crio 9074 that has 18 9870 Modules installed.  I would like to import values from an spreadsheet and then I would like to export results to a spreadsheet.  I keep getting errors that say I dont have the proper path.  Do I need to create a file path for these excel sheets in the DMA?  Are there any examples or good references I can use?
Thank you
(2,384 Views)
Your question is incoherently. And I'm still wondering how you got 18 C-Series Modules in an 8-slot Chassis?
You will find examaples using LabVIEW's Example Finder (Help>Find Example) and simply search for 9870 to get module specific examples.
Christian
(2,378 Views)
