pass Image to .dll
I found quite a lot of topics on passing images to a .dll, however I didn't quite find an answer to my problem.
I want to pass a reference to an Image to a .dll.
The reference is of Type void* myImage in the LabView configure-dll, and when I create a .c file, it changes to uintptr_t* myImage.
If I pass that reference to the function
     void*  IMAQ_STDCALL imaqImageToArray(const Image* image, Rect rect, int* columns, int* rows);
with the conversion (Image*)myImage, the function will always return a NULL-Pointer.
I know I can call all these function as VIs outside a dll, however I would really prefer calling them inside the .dll.
Some posts sounded as if this weren't possible, however I guess it has to be, as all the Vision-VIdo it.
Thanks for your ideas
Greetings
(3,384 Views)
Accepted by topic author kper
solved it myself, sorry to have bothered you!
For veryone who might run into the same problem:
Use the Image Datatype to Image Cluster.vi and pass the cluster to the .dll. It is in the folder National Instruments/LabViewX.x/vi.lib/vision/DatatypeCoversion
In the generated c-code, there will be a struct:
typedef struct {
    LStrHandle elt1;
    uint32_t elt2;
    } TD1;
where elt1 is the name of the picture and elt2 the address.
Say you've gt a function
void __declspec(dllexport) MyFunction(TD1 *ImageCluster, otherparameters)
you can now use the address elt2 to call tne imaq functions eg. like this:
Image *testImage;
testImage = (Image*) ImageCluster -> elt2;
uint8_t *ptr;
ptr = (uint8_t*) imaqImageToArray(testImage,imaqMakeRect(0,0,50,50),&x,&y);
Sorry again
Greetings
(3,371 Views)
