Impressive processing slow down due to UI refresh
I had this in a shady corner of my mind for a while,
it took dust because that requires a large refactoring
and I'm afraid doing it with Labview. A text based
programming language offers far more flexibility
in that matter.
David Koch
Message 11 of 22
(2,020 Views)
@BrainDrain wrote:
Hi, I just found your question, when I was palying around with references for speeding up a graphical display.
As metioned before, the fastest update mechanism is using references. If you would write the information directly into the reference to your table display, the UI is updated instantaniously. Just have a lookat the screenshot below. The Vi on the left generates numbers and they are written into a property node of a reference. In my case the reference refers to an waveform chart that is part of an ohter application. Therefore, the reference  is handled by a global. If the value is changed on the left, the display immediatly updated on the right. Yes, there is no loop running on the right. But is does not matter. The display is updating even the vi is not executing as long the global contains the right reference!
To cut a long story short: if you directly write your array values into the appropriate reference, you don't have to wait for any UI update... so the update time should be the same as the array update time... without any further delay...
Best wishes,
What is in the Variable_Global? I tried to put there a reference of "Waveform Chart" on the middle window, but an error pops up.
Message 12 of 22
(2,018 Views)
in that matter.
David Koch
Not really my experience! In both cases it depends on the architecture of the software. That this feels such a big task simply means, that you either have employed a less than good design or that you are afraid of something that isn't there. LabVIEW code can be written just as moduler as text based code and offer similar refactoring costs.
One of the problems with LabVIEW is, that it is so easy to start with that many people that would never think about writing a C(++/#) whatever program will do so in LabVIEW and use pretty bad design archiitectures. And if you come from text programming, it is easy to paint yourself into a corner by trying to apply certain text programming specific patterns.
Rolf Kalbermatter  My Blog
Message 13 of 22
(2,003 Views)
the variable global is the Global variable I have used it to transfer the reference of the graph. Find enclosed the vi's Put them into the same folder. They should run ...
Message 14 of 22
(1,996 Views)
Opening several 'cpp/h' files in Notepad++, doing regexp search/replace on opened files.
Done.
Labview ?
Extracting, saving, organizing, linking, routing, modifying, duplicating, whatevering...
For instance, I just moved some VI files inside a subfolder.
Testand was refusing to execute them anymore since their relative linkage was broken..
I had to open each of them and click for 15 minutes on the relinker dialog box.
Labview ?
Boring...
David Koch
Message 15 of 22
(1,979 Views)
Well, if you talk about such a simple change that regexp copy/paste will just work, you certainly have somethinig much simpler in mind than rearchitecting the UI display to be more performant for such a test data structure.
Message 16 of 22
(1,974 Views)
Extracting a whole loop from a Labview diagram and relinking everything
is a bit less mundane/more complicated that redecorating methods' prototype.
David Koch
Message 17 of 22
(1,960 Views)
But that loop doesn't really need to be a huge monster if you use some proper state machine architecture. It's the same about copy/[pasting a multipage C loop into another part that has many application global and module global references for all kinds of hidden interdependencies.
Of course LabVIEW has it's pain points, just as C or C# has its own, but a LabVIEW program doesn't need to be a pitta in itself. It can be made in one however, but that applies for any programming language.
The small part of the diagram you show in the first post, clearly hints at a monster architecture with about 10 huge loops inside each other. That such an architecture is hard to restructure, I believe you immediately. But in C(#) you wouldn't have written a main() with 10 loops inside each other that span about the entire source code of your program. That would make it even more unwieldy than the LabVIEW program you now have.
Message 18 of 22
(1,948 Views)
Sure, however if one IDE doesn't suits your needs in CPP,
you can always try another one. Let's see :
Codelite
Eclipse
KDevelop
Codeblocks
SublimeText
Notepad++
Netbeans
Codewarrior
Visual Studio
IntelliJ IDEA
emacs
Labview ?
Labview.
Doesn't even have zoom features, user are requested to "find another way".
Doesn't have tabs, user are requested to "find another way".
Doesn't have refactoring, user are requested to "find another way".
Doesn't have what other languages have, user are requested to "find another way".
Or wait NI to implement it when it meet their own agenda. And get it through upgrade plan.
Does have some few cool stuff though. But does not address my issue.
David Koch
Message 19 of 22
(1,939 Views)
It sounds like to me that you are unwilling to learn the benefits of LabView has to offer and instead bash it and use some other text based language.
Message 20 of 22
(1,931 Views)
