In Labview 6, the width of the plot area is variable and depends on the number of digits of the Y scale. How can I disable this annoying automatic feature?
I wonder, how do you plan to see your numbers?
Just change a style of scale numbers formatting - without numbers at all. :0)
Then put numeric scale (slide for example) above the Graph scale with a transparent background. How do you like it now?
Sergey
(3,222 Views)
Read the article in developer's zone at the included link. It talks about this "feature" and how to work around it:
http://zone.ni.com/devzone/devzoneweb.nsf/opendoc?openagent&9BCFFD601B34DE5F862569AB00800BAE&cat=FFD0B3DB8F25D884862567930070A782
(3,222 Views)
Very useful. Thanks. Here follows what I did based on your answer and the article.
Labview.ini was not present on my machine. I had to create it and write the following lines:
[LabVIEW]
EnableAutoScales=False
Then, I saved it next to Labview.exe
For the executable, I created "myprog.ini" where "myprog" is the name of the executable. The file contained:
[myprog]
I saved it next to the executable.
It worked all fine.
For more information on labview ini file content goto:
http://www.brian.renken.com/LabVIEW/INI/
Thanks again, you cleared my problem.
(3,222 Views)
