 Hooovahh
			Hooovahh
			10-28-2013 08:42 AM
This is again one of those things that could be an Ideas Exchange to some, and a bug to others. If I have a 1D array, and I use the Index function it starts at index 0 without having to wire anything to the index terminal. If I use an In Place Element Structure and choose the Index and Replace Array I get a broken arrow if I leave the index terminal un wired.
Also If I wire an index with a value of 5, when I expand it down I expect it to index element 6, and 7, and 8 and continue for the size of the index function. Here again is where the native Index function behaves differently from the IPE index and replace. Is this a bug? Is this an Idea of how the IPE should work?
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
Solved! Go to Solution.
 comrade
			comrade
			10-28-2013 08:44 AM
I would expect the IPE to behave exactly like the index function. Didn't even realize it doesn't!
Kudos for the idea, Hooovah.
 Yamaeda
			Yamaeda
			10-28-2013 09:13 AM
I'd consider that a bug, the only difference should be that it works in the same memory, nothing else.
/Y
 tst
			tst
			10-28-2013 09:23 AM
It was already suggested here - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Provide-good-defaults-for-unwired-indices-of-the-array...
And here (which discusses a slightly different behavior with >1D arrays) - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-unwired-index-for-quot-Array-Index-Replace-Eleme...
We also had a discussion which touched on the topic of how the IPES behaves here - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Set-index-inputs-on-LVOOP-array-element-accessors-to-R...
10-28-2013 09:25 AM
When I posted this topic the forum made me search (as is expected) but in the forums nothing came up. Glad to see great minds are already thinking about this.
 ben64
			ben64
			02-09-2015 01:03 PM
