07-03-2011 11:52 PM
I am using Labview 2009, And while I am saving a simple VI connecting wires are getting blurry. What could be the problem?? Is it affect my program while running?
Solved! Go to Solution.
07-04-2011 01:09 AM
Go into Tools>>Options, select the Block Diagram page and find the section called Constant Folding. If the CF for wires check box is checked, then this is most likely the reason. You can uncheck the check box and it won't affect the way your code runs.
If this isn't the case, you should upload an image of what it looks like.
07-04-2011 11:29 PM
Thanks!
