In block diagram connecting wire getting blur while saving the VI in LabVIEW 2009
I am using Labview 2009, And while I am saving  a simple VI connecting wires are getting blurry. What could be the problem?? Is it affect my program while running?
(2,500 Views)
Accepted by topic author Prakash_Mahar
Go into Tools>>Options, select the Block Diagram page and find the section called Constant Folding. If the CF for wires check box is checked, then this is most likely the reason. You can uncheck the check box and it won't affect the way your code runs.
If this isn't the case, you should upload an image of what it looks like.
___________________
Try to take over the world!
(2,495 Views)
Thanks!
(2,473 Views)
