In need of advice
I have some error handling functions to be used on my projects.
specifically I spawn a error dialog to the user (using VI server) to both show the error and give the user the option to close the top most-level VI (is there are repeating errors (say in a loop) using a file>shut down menu option.
so I can drag the spawner and place it on any top level VI and have my error hangling.
Now, this functions I want to be able to use them on any project (universal) per say and since my style is to always include a panel closed? event which i ignore and do house cleaning before terminate my main program I can standarize this.
here are some links i visited while attempting to create panel close? event dynamically
http://zone.ni.com/reference/en-XX/help/371361H-01/lvprop/vi_pnl_closing/
http://digital.ni.com/public.nsf/allkb/81E9C1441900FFCE8625748F0055DBB0
this variant closes the vi but does not generate the efect of cliking on the "X button" the next link mentiones that "WM_CLose" it should behave like pressing the "X button". I also try "WM_Quit" but no joy.
http://stackoverflow.com/questions/3155782/what-is-the-difference-between-wm-quit-wm-close-and-wm-de...
method FP-CLose failed
function "Stop" acts like an abort
I though about moving the mouse (based on the size of the top most level windows FP) to where the "X button" is but iam hoping for a more elegant approach.
any help will be greatly appreaciataed.
Message 1 of 10
(3,606 Views)
are you using a state machine architecture?  if so, your error would queue up the cleanup state, which is what your Panel: Close? event would do.
aputman
Message 2 of 10
(3,591 Views)
NO.
I want to create a panel close? event.
regardless of what my architecture is, I do not whish unless it is absolutly necessary have to change my architecture to acomodate this nuisance.
Message 3 of 10
(3,582 Views)
I understand what you are trying to do but i don't think you can generate a panel close event without using a Menu....Exit command or clicking the "X".  Can you show a screenshot?  You are discarding the panel close event in order to do cleanup.  Where is your cleanup code...in the Panel: Close filter?
aputman
Message 4 of 10
(3,577 Views)
Are you familiar with User Events?  Have you tried them for this?
Jim
Message 5 of 10
(3,574 Views)
so from my dialog vi i want to be able to generate a panel close
(I can ofcorse create a dummy control and hide it and in its value change case, do whatever I do for my house keeping) but it would be my ugly option, because user cliking on X is my signal that I have to terminate all my process in a gracefull manner (clore reference, etc).
has any one even with the win32.dll variant been able to mimic a close (x) (not in G) so that LV can successfully capture it.
the last guy in this post mentions it.
http://lavag.org/topic/4020-how-programmatically-fire-the-panel-close-event/
Message 6 of 10
(3,564 Views)
I am able to create dynamic events for controls but I cant seem to be able to generate an event (panel close?) for a VI
Message 7 of 10
(3,562 Views)
I'm curious now.  I was going to create a user event and add it to the same event case as the Panel: Close filter.  I get an error that says "Filter events must have identical data to share a case."  So I am trying to create a user event with identical data so that maybe they can share a case.  Anyone know if this is possible or is there a way to find out the exact event data?  I can see that there are 5 different values (4 input, 1 output) but this isn't working.  They may not be in the right order.
aputman
Message 8 of 10
(3,548 Views)
If all you are doing in the Panel Close? filter event is discard the event, then I don't see a really good reason to try to get a filter event and a dynamic event to work in a single case.  I don't think they would work together anyways.  So just make another event case that does the same thing as the filter event using a User Event.
Message 9 of 10
(3,511 Views)
I don't have a particular use case for this.  It was more of a "curiosity killed the cat" sorta thing....just to see if I could get it to work.
aputman
Message 10 of 10
(3,450 Views)
