In the Picture control, how can I draw a small image at a specific offset within a larger image?
I could use the opposite of "Get Image Subset.vi", like a "Set Image Subset.vi".
The "Draw Flattened Pixmap" function would work if it would let me define the target position instead of the source position.
(3,087 Views)
Accepted by bmihura
You can use "Draw Unflattened Pixmap.vi". Here is an example:
Marc Dubois
(3,074 Views)
That works perfectly, thanks!
As a bonus, I also wanted to invert that image and found I could do it by simply adding the "Reverse Array" function to the array exiting the While Loop.
(3,053 Views)
