Include Simulink RTW in Labview RT without using SIT
I am working on my master thesis and got to the following problem:
my job is to include a Matlab/Simulink Model (Real-Time Workshop ist available) into Labview Real Time (PXIe). Since I just want to put data into the model an see what comes out, I would prefer not to use the Simulation Interface Toolkit (since it's also quite expensive).
Has anyone an idea how to accomplish this one?
Thanks, Andreas
(4,541 Views)
Hi Andreas
Without the SIT it is not possible to use a Matlab or Simulink Model in LabVIEW Real-Time.
Components of a Simulation (Simulation Interface Toolkit)
Configuring a Simulation on a Real-Time Target
Kind regards
Pixar
(4,510 Views)
Thanks for your reply, Pixar.
When reading through a lot of documents and blog/forum posts I've come across a possible solution. The magic word seams to be DLL. In theory it should be possible to generate a generic DLL with Simulink RTW, which then can be implemented into Labview RT.
So now I am looking for a way to compile a DLL with Simulink RTW. Additionally I have to say I've already read through this http://www.mathworks.de/support/solutions/en/data/1-2F3I19/index.html?product=RT&solution=1-2F3I19 and have to say: I have no license for Embedded Real-Time (ert).
Has anyone a suggestion for my problem?
Greetings, Andreas
(4,487 Views)
Still no solution Smiley Sad
Has no one experience with putting Simulink into LabVIEW RT?
Greetings, Andreas
(4,468 Views)
Accepted by topic author AndiKe
Hi Andreas
If you have a DLL from Simulink you can call this DLL very easy in LabVIEW if the DLL is able to run on a RT system:
How Can I Verify that My DLL is Executable in LabVIEW Real-Time?
You can call a DLL in LabVIEW with the Call Library Function Node (Functions Palette -> Connectivity -> Libraries & Executables)
If you are not able to build a DLL from the Simulink Model it is not possible to use it without the SIT.
Regards
(4,466 Views)
