Increase max parallel loops on deployed executable
Accepted by topic author RHryniowski
@altenbach wrote:
You need to set it in the parallel configuration and wire the desired number to P. If P is not wired (as in your case), it will use the number of CPU cores.
That is the good point! And here not only desired numbers, but also the value "-1" can be used, then this value will be taken from  configuration dialog box. In such cases I also wiring chunks and set it to 1 (but this not always necessary):
Message 11 of 12
(750 Views)
This worked, I had configured the Number of parallel loop instances via the dialog box and had assumed this was the setting that would be applied.   Thanks for the fix
Message 12 of 12
(730 Views)
