Increasing Font Size Shortcut... Not sure I'm doing it right
LabVIEW 2023 Q3
Before the ability to zoom in/out "CTRL +" was the quick way to increase or decrease Font Size.  Now it appears it's used to zoom in and out.  So when I went to check what the uh... I guess "shortcut" was to do this, it doesn't appear to work.  I tried both "CTRL and < or >"  and "CTRL and + and < or >".  Am I not doing this right or have I stumbled across a bug?
Message 1 of 10
(3,818 Views)
It is:
"Ctrl" and "<" to make the font smaller.
"Ctrl" and ">" to make the font bigger.
On my azerty keyboard, I have to press "Ctrl" and "Shift" and "<>" to make the font bigger because "<" and ">" are on the same key.
Raphaël.
Message 2 of 10
(3,808 Views)
@raphschru wrote:
It is:
Raphaël.
"Ctrl" and "< or >" does not work.
But, I tried "Ctrl" and "Shift" and "< or >" on my QWERTY keyboard, and that worked.  So would that be considered a bug?
Message 3 of 10
(3,787 Views)
No, it is not a bug.  Look at your keyboard a little closer.  '<' is Shift+',' and '>' is Shift+'.'.
Message 4 of 10
(3,773 Views)
Oh, duh, got it.  Thanks.
Message 5 of 10
(3,741 Views)
macOS:
As of LabVIEW 2023 (Q3)
Just as the ability to zoom in (or out) now defies "CMD-Shift +" (or "CMD-Shift -"),
the shortcut to increase (or decrease) Font Size has been re-defined to "CMD-Shift >" (or "CMD-Shift >").
Message 6 of 10
(3,239 Views)
macOS:
the shortcut to increase (or decrease) Font Size has been re-defined to "CMD-Shift >" (or "CMD-Shift <"--corrected).
Message 7 of 10
(3,235 Views)
It is a bug.
My keyboard has a separate < > key (next to left shift). To type < I need to press that [<>] key, to type > I need to press [SHIFT] + [<>]  key.
When I try to decrease the size of the font I hold [CTRL] and press [<>]. Nothing happens.
When I try to increase the size of the font I hold [CTRL] + [SHIFT] and press [<>]. Nothing happens.
So it is a bug. Perhaps it's not a bug on a standard US keyboard, but it's a bug on at least Slovenian layout.
The only way to workaround that is to change the keyboard layout to US QWERTY in Windows and use'<' is Shift+',' and '>' is Shift+'.'.
Message 8 of 10
(2,025 Views)
@blaz-kelbl wrote:
It is a bug.
I have almost similar German Layout (at least from < > keys point of view), and it works for both decrement and increment (with Shift).
Be sure that no other software registered the same hot keys.
Message 9 of 10
(2,012 Views)
@blaz-kelbl wrote:
It is a bug.
The Swedish keyboard is similar. Ctrl + < and Ctrl + Shift + > works for me. I typically tap it and often need 2 presses to notice any size difference. If holding doesn't work it might be a key repeat issue.
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 10
(2,000 Views)
