Increasing frequency results in unexpected behavior of generated signal
I am generating a composite signal using a sawtooth and square wave, which results in the desired signal as shown on the left. Unfortunately, when increasing the frequency past 1Hz, I get undesired results as shown on the right.
I have attempted to alter the sampling info with no luck. I have also attempted differing methods to produce the desired signal. I have noticed that before one of the partial components of the final signal enters a relay, the increase of frequency does not create any unexpected results. Although, after it has passed through a relay, the error begins to occur. This seems like the relay is not suited for higher frequencies, but I am unable to correct for this unexpected behavior.
Frequency of 1 Hz:
Frequency of 3Hz:
An alternate method I had attempted was to use the 'Simulate Arbitrary Signal,' though I was unable to find a way to increase the resulting signal's frequency.
Also, the signal has this grainy nature which I would like to make smooth and continuous. Is this possible? I eventually would like to reach a frequency of a few kiloHertz.
I have attached the VI.
Any help would be greatly appreciated. Thanks.
(2,649 Views)
Accepted by Mike310
The problem has to do with the block size and when the relay actually sees the sawtooth cross the threshold.
To resolve it, we have to do a point by point check and build our custom waveform on each iteration.
Philip
CLD
(2,626 Views)
I have been trying to fix this for days without success.
It works great now. Thanks for the help.
(2,610 Views)
